Hi Support team,
I read this post :
https://community.pix4d.com/t/2833-Trouble-getting-a-solid-mission#gsc.tab=0
and had the same issue recently , the autofocus of X5 works fine after tapping the screen even when still on the ground in most of the case, but recently i got a blurred mission by doing same handling.
So is it needed to start with DJI GO then do an autofocus at mission altitude then close dJI GO and pass to pix4D and start mission?
Is there a way to have X5 autofocusing without this ?
Is forcing DJI GO to close an issue as it is sometimes asked by Pix4D ?
To be more accurate , my question is :
- Does pix4D Capture manage an autofocus at the beginning of the mission by itself (if X5 is setup in autofocus mode) as this is the
feeling i had from the beginning ?
- Or does user have to do an autofocus at mission altitude then close dJI GO and pass to pix4D and start mission?
I need to do so (step 2) from a recent time , not sure it could be related to latest version of pix4DCapture i had downloaded on 6th April then on 21rst April 2017.
Mission are grid missions i setup with overlap of 85 %
Regards
Benoit
Just uploading last flight logs
I can provide you full logs
I get errors like this one :
event":“Error”,“metaData”:{“message”:“Error getting gimbal serial number with error: Not supported”},“sessionInfo”:{“deviceManufacturer”:“samsung”,“deviceModel”:“SM-T710”,“deviceOS”:“6.0.1”,“sessionID”:“58da4e9f-9af8-4ef0-ac27-505ebf34a988”,“userName”:“benoit.filliatre2@free.fr”,“version”:“2.0.42”},“timestamp”:“2017-04-24 13:30:53.735+0000”}
Gimbal is the standard X3 X5 Gimbal from DJI
A full line is :
{“droneInfo”:{“cameraName”:“Zenmuse X5”,“droneType”:“Matrice 100”,“flightControllerFirmware”:“03.01.06.103”,“remoteControllerFirmware”:“1.7.60”},“event”:“Error”,“metaData”:{“message”:“Error getting gimbal serial number with error: Not supported”},“sessionInfo”:{“deviceManufacturer”:“samsung”,“deviceModel”:“SM-T710”,“deviceOS”:“6.0.1”,“sessionID”:“58da4e9f-9af8-4ef0-ac27-505ebf34a988”,“userName”:“benoit.filliatre2@free.fr”,“version”:“2.0.42”},“timestamp”:“2017-04-24 13:30:53.735+0000”}
Regards
Benoit
EDIT from Pix4D Support : We have merged the comments that you have added to the post to your original post. Please consider editing your original post if you would like to add more information to the question, click “Post actions > Edit” at the top left corner of the post.
