Good job! I’m stunned by how well the model looks, considering there is snow all over the place! As you say, it’s not the most pleasant terrain to work with…
Have you used the merging procedure? If yes, how many subprojects did you create? In any case, cool example of using terrestrial and aerial images in a single project.
Ps: I think I found the Christmas tree in the carport :D
3 sub projects were merged together. Aerial, House and Carport were merged after step 1.
6 common manual tie points were used in each sub project. After merge I added a few more, re-optimized the project and the images aligned nicely. (Only 1 image was not calibrated, which was a blurry image due to focus issue)
Very nice, Jaakko! How many rounds did you fly with oblique angle and what were the flying heights? And what angle from nadir upwards did you use with each height?
In Finnish: Terveiset täältä Kuopiosta. Samat “lumiongelmat” mallinnuksessa ne on täälläkin.
Double nadir grid and the height was 30m. GS Pro was used to planning the flight. All the nadir images were taken manually with DJI Go app.
In Finnish: Haasteita tuo lumi tosiaan tuo Eli tuossa projektissa lentelin vaan pari kohtisuoraa reittiä koko tontin alueella. Vinokuvat otin kaikki manuaalisesti ja tein silleen, että tuossa talon terassin kohdalla laskeuduin tuolta lentokorkeudelta melkeen maanpintaan asti ja koko ajan muuttelin tuota kamerakulmaa. Sama homma autokatoksen kohdalla. Noista kuvista löytyi sitten helposti yhteiset “sidontapisteet” noille järkkärin kuville. Takapihalta nuo yhteiset pisteet löytyi hyvin räystäskourujen päistä. Heitähän vaikka sähköpostia, jos haluat joksus raatailla lisää. Mukava välillä kirjottaa suomeksikin näistä hommista. etunimi sukunimi ät gmail.com
