Good day community
I have a drone ortho imagery that has lines running across the flight path.
Frontal overlap is 75% and side overlap is 60% - on flight plan.
Any idea why i have these lines on the imagery??
Good day community
Hello @bmtshatsha, This usually happens due to the low overlap. In your case, the side overlap is low. This might be the reason for the issue if there is no issue in the camera optimization. So, I would suggest you to at least have 70% side overlap during the image acquisitions, the best image acquisition parameter would be 75% front and 75% side overlap.
