SONY A6000 카메라를 통해 측량하는 유저분들이 많은걸로 아는데요. REACT VERSION에서는 ILCE 6000 을 지원하지 않는다고 하네요. 활성화 해주시면 감사하겠습니다.
Hi, ILCE-6000_30.0_6000x4000 is in our database, make sure you use the original resolution of the camera and not cropped resolutions.
Hi, the 20 mm is not supported. the focal length of the supported camera is 30 mm. You can however, try processing with our XML workflow:https://support.pix4d.com/hc/en-us/articles/360039273312-User-provided-camera-parameter-file-for-Pix4Dreact
