Hello, after running the pix4d program on Windows 10, I get Kernel Security Check Failure every time. I’m using a laptop with an i5, 1.8ghz, 8gb memory. Processor runs at 100% during program…
Is this program an overload for my laptop?
Regards, Mark
Regards, Mark
Dear Mark,
We would recommend you to check the hardware/operator system of your computer. Pix4Dmapper shouldn’t cause the Kernel Security Check Failure. We believe that the source of the problem is not the software, but something else related to your PC.
Please make sure you have the following:
We would also recommend you to check your RAM in case this might cause the problem by following the steps:
You can also check the cause of your problem by looking on the log file:
If the problem persists, we recommend you to consult an IT specialist.
Best Regards
I am having Kernel Security Check Failure problem in my Pc.
It take me 3 days to fix this issue
And I was finally found the Fix.
here is the link
if anybody wanna look
http://www.deskdecode.com/kernel-security-check-failure-0x00000139/
hi friends if you are wondering how can you fix this error it is very easy to fix named security check.
