Looking to get pix4dcatch data into pix4dsurvey?
Yes. You first need to process the data in either PIX4Dcloud, PIX4Dmatic, or PIX4Dmapper. Once processed then you can either drag and drop the LAS file. Or there is an option in Matic and Mapper to open directly in Survey. Regardless of your method, the data needs to be processed first.
