Hello I want to use Catch to map an internal high security area where I have clearance but cannot share any information via the cloud. Is it possible to directly link Catch to Mapper without using the cloud? i.e. download the images from iPad ? when I try to access the iPad I cannot view the catch images. regards Andy
Welcome to the Pix4D Community!
It is possible to export your images without using PIX4Dcloud. You can find the relevant instructions here:
https://support.pix4d.com/hc/en-us/articles/360044095312-iOS-How-to-export-PIX4Dcatch-projects
Let us know if you need any further help.
Cheers
Daniele I am using an iPad with the laser, if I save images locally from iPad to transfer to PC based standalone mapper I wont be able to use the depth as it is this part the LiDar adds right?
This is true; you won’t be able to use the depth (LiDAR) data with PIX4Dmapper.
However, you could give a try to PIX4Dmatic:
Let me know if you need any further support.
Cheers
