Hello, Thank you very much for the help you can give me.
I don’t know what to do anymore because for me it is impossible to make an orthomosaic of a DJI mavic 2 enterprise advanced. I no longer ask for the thermal, but I can’t with the visible images. I do the mission with the DJI program. GSD 1.14cm/pixel. 80%-80% overlap.
I leave the error that Pix4D mapper gives me.
I leave this link to download imagener. It is a small portion of the rest of the roof deck.
http://gofile.me/5sC3J/lZPMJrZz1
Thanks a lot
Log:
[2022.09.06 17:58:56][ 18%RAM][ 1%CPU][UI]: New Project clicked.
[2022.09.06 18:00:45][ 17%RAM][ 0%CPU][UI]: New Project clicked.
[2022.09.06 18:02:23][ 25%RAM][ 4%CPU][Processing]: ProjectLoading
[2022.09.06 18:02:23][ 25%RAM][ 4%CPU][Processing]: ProjectLoaded
[2022.09.06 18:02:29][ 25%RAM][ 1%CPU][UI]: Processing Start clicked.
[2022.09.06 18:02:29][ 25%RAM][ 1%CPU][Processing]: Step1Running
[2022.09.06 18:02:29][ 26%RAM][ 1%CPU][Processing]: Substep Keypoint extraction started.
[2022.09.06 18:02:29][ 26%RAM][ 1%CPU][Processing]: Gather image information
[2022.09.06 18:02:30][ 26%RAM][ 1%CPU][Processing]: Generate normalized/thumbnail images
[2022.09.06 18:02:30][ 25%RAM][ 1%CPU][Processing]: Computing keypoints
[2022.09.06 18:02:39][ 28%RAM][ 65%CPU][Processing]: Write Keypoints.
[2022.09.06 18:02:39][ 28%RAM][ 65%CPU][Processing]: Substep Keypoint extraction finished.
[2022.09.06 18:02:39][ 28%RAM][ 65%CPU][Processing]: Substep Keypoint matching started.
[2022.09.06 18:02:39][ 28%RAM][ 65%CPU][Processing]: Generating pairs
[2022.09.06 18:02:39][ 28%RAM][ 65%CPU][Processing]: Computing matches
[2022.09.06 18:02:40][ 28%RAM][ 65%CPU][Processing]: Write matches.
[2022.09.06 18:02:40][ 27%RAM][ 65%CPU][Processing]: Write matches.
[2022.09.06 18:02:40][ 27%RAM][ 65%CPU][Processing]: Substep Keypoint matching finished.
[2022.09.06 18:02:40][ 27%RAM][ 65%CPU][Processing]: Initialize automatic tie points.
[2022.09.06 18:02:40][ 27%RAM][ 65%CPU][Processing]: Building automatic tie points.
[2022.09.06 18:02:40][ 27%RAM][ 65%CPU][Processing]: Substep Camera calibration started.
[2022.09.06 18:02:40][ 27%RAM][ 65%CPU][Processing]: Analyse automatic tie points.
[2022.09.06 18:02:43][ 27%RAM][ 15%CPU][Processing]: Analyse automatic tie points.
[2022.09.06 18:02:43][ 27%RAM][ 15%CPU][Processing]: Compute number of matches.
[2022.09.06 18:02:43][ 27%RAM][ 15%CPU][Processing]: Initialize calibration
[2022.09.06 18:02:55][ 27%RAM][ 4%CPU][Processing]: Initialize calibration
[2022.09.06 18:03:06][ 27%RAM][ 5%CPU][Processing]: Initialize calibration
[2022.09.06 18:03:08][ 27%RAM][ 3%CPU][Processing]: Initialize calibration
[2022.09.06 18:03:13][ 27%RAM][ 4%CPU][Processing]: Initialize calibration
[2022.09.06 18:03:18][ 27%RAM][ 24%CPU][Processing]: Calibrate
[2022.09.06 18:03:18][ 27%RAM][ 24%CPU][Processing]: Initialize calibration
[2022.09.06 18:03:18][ 27%RAM][ 24%CPU][Warning]: No initial frame
[2022.09.06 18:03:18][ 27%RAM][ 24%CPU][Error]: no blocks computed
[2022.09.06 18:03:18][ 27%RAM][ 24%CPU][Processing]: Substep Camera calibration finished.
[2022.09.06 18:03:18][ 27%RAM][ 24%CPU][Error]: No calibrated cameras.
[2022.09.06 18:03:18][ 27%RAM][ 24%CPU][Processing]: Substep Report generation started.
[2022.09.06 18:03:18][ 27%RAM][ 24%CPU][Processing]: Read keypoints.
[2022.09.06 18:03:18][ 27%RAM][ 24%CPU][Processing]: Substep Report generation finished.
[2022.09.06 18:03:18][ 27%RAM][ 24%CPU][Error]: Error e0046: Processing failed. No calibrated cameras.
[2022.09.06 18:03:18][ 27%RAM][ 24%CPU][Processing]: ProjectLoaded
