How do I export a Visualisation image
So I have a lovely coloured, shaded ortho with the shading representing elevation, created under the Visualization menu.  How do I export that image as a full resolution JPEG for the client? I see no Export or similar options in the UI.
Hey Donald,
Your processed outputs should be in a folder similar to this DSM:  your_project\3_dsm_ortho\dsm\your_project_dsm.tif
Orthomosaic: your_project\dsm_ortho\mosaic\your_project_transparent_mosaic_group1.tif
You can access to that folder above either manually navigating to it or under Process tab then Open Results folder.
They should be in a .tif format but you could use either GDAL or QGIS to convert it to a JPEG.
