Capturing/Exporting high-quality images from the 3D-model (different perspectives)
I’ve modeled a 3d-model of an rock cut and would like to export a panorama view from the front looking at the face of the rock cut. Is there a way in Pix4D to make/export an image this way. In Pix4DCloud you can take a screenshot but the image quality is too low to be of any use. In Agisoft Metashape you could for example make an orthomosaic from any angle you wanted, not just from the top. Is this possible on some of the softwares of Pix4D?
Thank you for your help,
Patrik
Hi @patrik.kujanpaa,
Thank you for your message.
Please note that PIX4Dmatic does not have the possibility to create mosaics from angles other than from the top.
You might be interested in this feature request:
Please add your comment in the shared thread, motivate your use case and vote using the “vote” button at the top-left corner of the thread.
Alternatively, you could achieve your goal using PIX4Dmapper:
Let me know what you think.
Kind regards,
Daniele
