Is there a way to edit out white holes in my orthophoto?
You may want to try using Mosaic Editor. The link below has more information on how to use it.
Kind regards,
Thank you.
I did manage to edit the mosaic but when I bring it in to QGIS it still has the holes.
Thank you for replying. I did do the save and export. Which brings another question. Do you have to save and export each individual region that you make or can I do-them all after they’re completed?
Jim
Hello Jim,
It is not necessary to export every time you made changes; however, you may want to save it from time to time because if you don’t, the edits you made will be lost when you accidentally close the projects.
Kind regards,
Thanks!
