GCP conversion issue
I have been trying to export a project in both mapper and matic.
I can get the outputs needed in mapper with the GCPs i have but i cannot import that GCP file into PIx4dmatic.
It either says Parse error line 1 column 4 or if i bypass that by importing a txt file then the screen goes black and i cant see the photos that i have uploaded until i have deleted all the gcps
GCP & MTP.txt (717 Bytes)
I have uploaded the GCP txt file. PIX4d Matic is saying that the co-ordinate system is WGS84 UTM 55S.
The GCP co-ordinate system should be wgs 84 - height above ellipsoid.
I had to import a prj file into pix4d mapper to get it to work properly there
Thank you for your message.
I replied in the direct support ticket.
The GCP format seems to be correct:
cheers
