I get an error when I attempt to use a state plane coordinate system with my images. It states “Error while converting coordinates : (inf, inf, inf) from WGS 84 + to EGM96 height to NAD83 / Texas South (ftUS) + NAVD88 height (ftUS)”. This happens if I import the GCP first or import the images first and then the GPC. The error is attached.
The EPSG used for the GCP are 2279 horizontal, 6360 vertical, GEOID18. Format of GCP files is a CSV with Point#,Northing,Easting,Elevation (N,Y,X,Z) exported from Trimble TBC. I also tried Point#,Easting,Northing,Elevation (N,X,Y,Z).
I bypassed the problem by exporting from TBC as WGS 84 UTM 14, EGM96 to match the image coordinate system (I’ll convert the output after it’s done). It’s probably still something you want to fix, so attached is the file with Pt#,Easting(X),Northing(Y),Elevation.
I had a look at them and I would suggest using EPSG:6586 - NAD83(2011) / Texas South (ftUS) instead of EPSG:2279 - NAD83 / Texas South (ftUS), as the GCPs` Horizontal Coordinate System.
Let me know if this helped.
Nikoleta
Cookie Policy
