I just recently upgraded to the latest version of the mapper (4.7.5) When importing my .txt file for GCP Pic4d screws up the formatting of my points. Any suggestions?
Hi Glenn,
Thank you for your message.
Were you able to use the same .txt file for Ground Control Points (GCPs) with previous versions?
Make sure the file follows the format described here:
cheers
