GCP FORMAT
Hello
I extracted a GCP file from my EMLID RS2 and it is in the following format (attached)
Project 2main.zip (774 Bytes)
Pix4d doesn’t accept it like this. Do I need to transform it?
My coordinates have to be like this (???)
4d 452911,285 4332254,121 22,660
Hi @nikolaospaschalis,
Thank you for your message.
Here you can find additional information about the format of the Ground Control Points file:
It should contain four or six columns per line for 3D GCPs and 3 or 5 columns per line for 2D GCPs, and use a comma to separate the columns.
thanks !!!
One more question, please …
After generating a Quality report I get a yellow mark at the quality check and Georeferencing, why is that?
The yellow warning is shown in the Quality Report when
GCPs are used and the GCP error is more than 2 times the average GSD.
or
when no GCPs are used
You can find more information here:
In your case, it seems that the GCP error is between 2 and 4 times the average Ground Sampling Distance (GSD).
To resolve the problem, please read these possible causes with suggested solutions:
  • Not enough GCPs were used given the size of the project.
    • Add additional GCPs. A minimum number of 3 GCPs is required but we recommend including at least 5 to 10 GCPs. When the topography of the area is complex adding more GCPs could lead to a more accurate reconstruction.
  • Accuracy values for GCPs are not properly set .
    • If the accuracy of the GCPs is known then it should be entered instead of the default values in the GCP/MTP Manager.
    • When using the default accuracy values in projects that are set to imperial (ft) then the GCP accuracy should be adjusted to 0.066.
  • Poor GCP marking: The quality of GCP marks can be estimated by reviewing the projection error for each GCP shown in the quality report. All projection error values should be less than 1 pixel.
  • GCPs are not marked on enough images.
Hello, further to the above.
When I try and import the below 3D GCPs, the Z value does not appear in the GCP manager on Pix4D mapper.
Have I got something wrong in the CSV?
Thank you.
1A_Final,288004.689666667,7600638.97933333,-11.0633333333333
1B_Final,288042.403333333,7600580.91166667,-8.44633333333333
1C_Final,288324.356333333,7600868.60433333,-11.5813333333333
1D_Final,288360.499,7600836.32166667,-9.18466666666667
1E_Final,288824.695666667,7601238.161,-10.9736666666667
1F_Final,289521.600333333,7601734.593,-10.521
1G_Final,289479.596666667,7601788.311,-10.4186666666667
2A_Final,289703.787,7601941.73833333,-10.5156666666667
2B_Final,289857.055666667,7602050.984,-10.5766666666667
2C_Final,290581.254,7601884.82633333,-10.2823333333333
2E_Final,291360.700333333,7601796.48333333,-10.9276666666667
2F_Final,291365.688666667,7601774.107,-9.772
2G_Final,291182.145,7601683.468,-10.3486666666667
2H_Final,290323.662,7601923.03966667,-10.112
3A_Final,292026.331666667,7601597.73733333,-10.9306666666667
3B_Final,292896.946666667,7601173.982,-10.228
3C_Final,292780.550333333,7600857.05733333,-3.74533333333333
3D_Final,291370.452333333,7601715.52033333,-10.1536666666667
3E_Final,291379.419333333,7601801.379,-11.162
3F_Final,292324.502,7601436.164,-9.89266666666667
4A_Final,293580.890333333,7600938.303,-9.64666666666667
4B_Final,293767.514333333,7600827.097,-9.768
4C_Final,294183.523333333,7600757.277,-9.75266666666666
4D_Final,294744.497666667,7600731.61166667,-10.0986666666667
4E_Final,293598.156333333,7601038.65366667,-11.341
5A_Final,295380.429666667,7600596.54966667,-9.738
5B_Final,295332.399666667,7600506.55266667,-9.995
5C_Final,296113.934666667,7600775.527,-9.62133333333333
5D_Final,296183.35,7600782.13266667,-9.04766666666667
6A_Final,296754.193666667,7601046.45433333,-10.8743333333333
6B_Final,296790.594,7600967.16733333,-9.76866666666667
6C_Final,297389.103,7601185.49333333,-9.421
6D_Final,297396.085,7600977.456,-7.95733333333333
7A_Final,298149.894,7601294.21633333,-9.828
7B_Final,298623.022,7601492.29866667,-9.11066666666667
7C_Final,298772.511,7601410.27933333,-9.90233333333333
7D_Final,299106.515,7601833.38766667,-8.90333333333333
7G_Final,298605.337666667,7601443.73633333,-10.5836666666667
Deck Corner_Final,298806.389,7601275.95433333,-9.151
Hi @josh.abbott,
Can you please provide a screenshot of your GCP manager window? Which Coordinate Reference System did you select?
