Hi JongHoon,
Did you have the chance to take a look at this post?
https://community.pix4d.com/t/5876-FLIR-Duo-Pro-R
Even though the camera is not in our database, you can define the camera model and calibrate it as per the instructions that are given here.
Assigning a wrong camera model will not help the reconstruction since the optimization of the internal parameter will start from wrong initial values. To correctly process your datasets please the workflow I have mentioned at 1.
At the moment, you will have to split the images into two projects: RGB and thermal. Following you can create two projects that can be further merged. Please seeProcess dataset with both thermal and RGB imagery.
Cheers,
Ina
