FLIR Duo Pro R 3D modeling
I’m shooted pictures with Matrice600 & FLIR Duo Pro R
But I couldn’t make a 3D modeling with automatically selected camera model…
So I tried other camera model, ( I randomly selected the camera model: FLIR_13.0_640*512 & CanonPowerShotSX230HS_15.0_4000*3000)
 And successed to have some 3D results.
For short, I have 3 questions…
  1. Is FLIR Duo Pro R camera model not in the Pix4D program?? Is that the reason for I cannot get 3D modeling…?
  2. With selecting other cameras, I could have 3D models. However the building walls ripped off.
  3. Is it okay to process 2000 images at once? One picture has both thermal & RGB.
Help me!! T.T
Hi JongHoon,
Did you have the chance to take a look at this post?
https://community.pix4d.com/t/5876-FLIR-Duo-Pro-R
  1. Even though the camera is not in our database, you can define the camera model and calibrate it as per the instructions that are given here.
  2. Assigning a wrong camera model will not help the reconstruction since the optimization of the internal parameter will start from wrong initial values. To correctly process your datasets please the workflow I have mentioned at 1.
  3. At the moment, you will have to split the images into two projects: RGB and thermal. Following you can create two projects that can be further merged. Please seeProcess dataset with both thermal and RGB imagery.
Ina
