Error: Failed to write Exif data error occured step3
just encountered,
in step 3, using ver. 4.1.24,
please help! Projects are on hold.
Roland
actually this plea goes out after all day attempts.
Hi Ronald,
I am glad to hear that you solved the issue. Could you share some additional information on how you resolved the issue?
Certainly not the first person with this so some sort of hardware conflict or bad hardware is out there.
https://community.pix4d.com/t/4125-Failed-to-write-Exif
https://community.pix4d.com/t/3581-Error-Failed-to-write-Exif-data
My rig has processed a failed project without issue so it isn’t a global issue but something that needs fixed.  In the meantime, I do processing as a service if you need to get some projects done before this gets resolved.
Ive still no resolution! Sorry if I implied I did.
for anyone who is more computer savvy than I and for what its worth, below is what im running.
