Hi Derek,
Have you tried the solutions described in this page?
If it does not provide you a solution, let us know.
Hi Derek,
Tried all listed solutions, Removing deep packet analysis changed the error to this:
Error e0706c: Could not authenticate. Check your internet connection. Failure: SSL handshake failed
no other results
Hi Derek,
This error may be the result of three possible problems:
Add also cloud.pix4d.com and **https://aws.amazon.com/s3/ or https://aws.amazon.com/ **sites as trusted in the operating system.
You can also check this article if you have not done it already:
Error: “Network error: Please check your internet connection. SSL handshake failed”
If you still experiencing the same issue, the next step is to completely uninstall Pix4D Desktop and install the stable version once again.
Hope this will help,
