Cretaing Triangle Mesh stuck at 40%
Hi Paul,
We saw in your reply to another post (https://community.pix4d.com/t/4538), that the issue related to the mesh generation, was stuck at 40% but that after 2 days and letting your computer process, the mesh could finally be created.
We first wanted to know if you gave this workaround a try?
  1. Process step 2 without generating the mesh in the processing options.
  2. Go in the processing options: Process > Options… under the tab step 2 select the mesh as output.
  3. Generate the mesh from the menu bar: Process > Generate 3D Textured Mesh.
Could you please upload to our Cloud Services your dataset, plus the log and p4d files, and write us to support@pix4d.com?
If you still have a project that could finish the mesh generation and another that remained stuck at 40% it would be very useful for us to have both.
It is also possible to use a server or another service like WeTransfer, Dropbox, Google Drive, etc. As you prefer.
Like mentioned above, could you also provide the PC configuration?
This issue is not fixed yet, our developers need more investigation and your case would be very interesting.
It is related to some function in the mesh generation algorithm, the hardware configuration, and the input images.
Perhaps if you try to process the same project on a different computer it will work.
We look forward to hearing from you.
