good afternoon, i need some help. i am wanting to use iphone 7 to work with dji mavic air with pix4dcapture. I’ve installed the DJI GO 4 that I can take off In pix4dcapture I program the mission, when I run the start the connection frame to the drone appears, this is where you tell me you can’t connect. I’m connected to the drone via wifi.
In the Checklist, only the connection to the drone fails.
Can you help me?
thankful
Good afternoon,
I appreciate the help, the conflict is over the use of both applications at the same time.
Regards
