Clipping donut hole in Mesh
Is it possible to remove an area within the triangle mesh?  I see that you can clip to an area, but I want to remove a area from the center of my model creating essentially a donut.
Hello Paul,
You can edit the point cloud (check this link for more info) and assign the points you want to remove in the deleted point group.
Then, Save the project and Process > Generate 3D Textured Mesh : 202560669.
Best Regards,
