Hello
I drow and classificated some object as “disabilited”, then executed “classification point cloud. Then I have tried to make DSM model with no layer of “disabilited clasificarion point cloud (NDP), but the DSM result includes that part of the DSM model.
Thanks!
Hi @vxcaceres
Once you made changes by disabling the points, you can proceed with step 3 immediately after editing the points. The changes will not be saved if step 2 is run gain.
Also, the disabled points will only apply to the DSM and DTM but not the orthomosaic or a reflectance map.
For more information:
[Tutorial video] How to edit the 3D Point Cloud
How to edit the point cloud in the rayCloud
I hope this helps. If the points are still showing in the DSM/DTM after running step 3 immediately, you could share with us some screenshots of the properly disabled points showing up in the DSM model. We are happy to take a closer look.
Rosana (she/her)
