Capture pro - Geofence Error in checklist
Hi, I just tried to start a mission for a DLI Phantom Pro V2.0 drone but the checklist has an error For Geofence. So I can’t start the mission. There doesn’t seem to be a troubleshooting for this and the manual doesn’t mention it in the checklist list. Help!
Hi @igrowns,
Welcome to the Pix4D Community :handshake:.
It is likely that the reason you are having this issue is that the mission is outside the geofence defined in the drone vendor app. It looks like you are using a DJI drone, so you must first connect to the DJI Go app, then change the geofence parameter in the drone vendor app, and then try again.
Cheers
