Issue:
We recently became aware of errors when processing datasets from the Autel Evo II 6k using PIX4Dreact and PIX4Dfields. Images can be loaded into PIX4Dreact/PIX4Dfields but processing will fail with an error code R0010. Investigations point to conflicting Exif tags found in the recent firmware upgrade V0.3.0.0.
Solution:
As a temporary workaround, a custom XML camera parameter file can be used to process data with this drone. The file is attached to this posting.
I have also experienced this problem, the error code that is, using a DJI Zenmuse XT@. I know this is a thermal camera, however, I use the JPG files (not the radiometric files). I have done this in the past have had success with it. I believe the problems started with the firmware upgrade to 01.4.02.
Is there a way to revert back to the previous firmware update so that I can finish my project.
I have sent two notices to tech support, but have not heard back. Last ticket # was 125175.
That’s strange, anyway, I see from the logfiles some library is missing.
Could you re-install PIX4Dreact again? You can download from here and just install it again
