Buenas noches, la aplicación Pix4D no reconoce el drone Phantom 3 4K, solo reconoce el standard, advantad y profesional, quisiera preguntar y ojalá alguien me asesore en cuál aplicación puedo utilizar que se asemeje a Pix4D para poder realizar levantamientos topográficos con mi Drone Phantom 3 4K
Hello @luis.rodriguez,
The Phantom 3 4K is not officially supported by Pix4Dcapture. However, you may be able to fly your mission if you select the appropriate settings in Pix4Dcapture:
- DJI Phantom 3 4K: Select Phantom 3 Advanced or Professional in Pix4Dcapture’s settings
Gracias por contestar, pero ya intenté de esa manera y no logra detectar comunicación con mi Drone, ojalá pudiera orientarme más al respecto.
Thank you for answering, but I already tried that way and you cannot detect communication with my Drone, I wish I could get more information about it.
Sorry to hear that. As the drone is not officially supported we can’t guarantee that it will function for all of the case. I would still suggest you go through all the basic checks and troubleshooting steps as it will solve most of the issues that can be encountered if properly followed.
