Phantom3 4K, Es compatible con la Pix4D Capture
Good afternoon!
I can not get my Phantom 3 4K connected to the Pix4D Capture application, Is the App compatible with the Phantom 3 4K?
Hi Ivan,
We have not tested the Phantom 3 4K on our side, so we cannot give any guarantees on the compatibility.
However, I can recommend to select a drone in the settings (before starting the mission) that has a similar connection mode (Wi-Fi or USB cable) which would be the Phantom 3 Advanced or Professional in your case.
More on drones’ compatibility with Pix4Dcapture in this article: https://support.pix4d.com/hc/en-us/articles/203991609
Maybe someone from the Community has experience with this drone and can give you more hints :slight_smile:
