I am using Inspire 1 drone with zenmuse X3 camera. I am making the following steps:
Set the option for shooting images in raw or jpeg+raw in DJI GO app
Then I make the mission in Pix4Dcapture app, not cloasing the DJI Go app
Before starting the mission, camera settings get messed up and reset the camera parametres previously set up in DJI GO app.
As a result after the mission I only get jpeg without DNG images. Last year during the summer time, I was able to obtain at the same time the JPEG and DNG images (for the image settings in DJI GO - JPEG + RAW), but that was with the older version of Pix4D, DJI Go and older DJI Inspire 1 firmware. Before creating a project in Pix4D software I converted DNG to Tiff following the Camera Requirements For Precision Agriculture - Pix4D Support steps to get NDVI maps.It was successful.
Did you make some adjustments to the new version of Pix4D, so it resets the camera settings in the DJI GO?
Also I would like to ask if there is anybody else complaining about the problem same as mine?
Generally, I’m not sure if this problem is regarding the Pix4D, or DJI GO, or new DJI Inspire 1 firmware.
Thank you very much in advance,
Best regards.
Bojana
