I’m in a trial and on Pix4D Mapper, it looks like the 3D Mesh model resolution is fairly low, at least compared to what Drone Deploy outputs and the default settings in Agisoft Photoscan (which isn’t cloud). I couldn’t find any settings in the cloud to control things like point cloud density, mesh, and textures so if you want a more dense/detailed model, is using Desktop the only option? If so, can someone confirm what the main settings that the cloud processing defaults to so I know where to go in Desktop and change them to higher resolution settings?
