I have both cameras and use the X4S for mapping and the X5S for videography. Now i’m fully aware that the global shutter of the X4S makes it the ideal camera for mapping however the X5S with 25mm lens is, if i’m not mistaken, twice the focal length of the X4S. This of course means that my GSD would be better wit hthe X5S at the same AGL.
I know Pix4D can correct for the distortions introduced by the rolling shutter so if i needed to stay high but still aquire an good GSD, would the X5S still do a good job. What would i be looking for if I was to do a comparison?
The default X5S is having a 15mm focal length. In Pix4Dcapture that the default X5S parameters that are taken into account when planning a mission.
If you decide to change that lens to use a 25mm focal length, then you will have to implement it as a custom camera in the iOS version of Pix4Dcapture to still have the correct overlap. Note that we can not guarantee that it will work as we do not support this kind of configuration.
However, we assume it may work but if you can set a timelapse in the native drone application and set a custom camera in Pix4Dcapture. We don’t have user feedbacks about this type of configuration and we will be glad to get some so don’t hesitate to share if it works for you or not.
Then, if you can fly with your X5S, for the same GSD than the X4S, you will be able to fly higher and then cover a bigger surface.
We have reason to believe that whatever rolling shutter distortion that may be present in images captured by your drone will be marginal and should have little to no effect on your project results. To limit it if occurring, we suggest flying slower and/or higher to reduce the amount of linear rolling shutter distortion that is present in your images.
Hi Gael,
I am operating a Matrice 600 Pro with Zenmuse X5S and 12mm Olympus lens (iOS version of P4DC). I recently set up a custom camera and entered the specifications for the 12mm lens and of cause the sensor’s parameters and so on. The result was that no picture was taken in a double grid mission. I avoid to run DJI Go in the background as this may cause conflicts, so I wouldn’t be able to trigger by interval shots.
It is pretty sad that the focal length can’t be edited in P4DC. The calculated time for the double grid mission with the 12mm lens was about half of the time needed with the default one. The drone flew way faster, too - but no pics.
And, by the way: Is there a reason why there’s no camera view (black screen)? DJI Go shows a live view, so the camera seems to be okay. Doesn’t work with the Zenmuse X5 default selected camera either.
Tom
Cookie Policy
