Hi, I’m Victor, i have a lot of tiles from a drone flight (Ebee Plus) over a farm , this time when i tried to make the orthomosaic, this happened:
I tried to process it on the pix4D cloud, an got the same results, the result was a warped image… There is a way to clamp those point to the ground? because i need only the 2D image, for visual analysis.
If someone knows how i can proceed to make the orthomosaic without the warping, i apreciate the help.
I’m using Pix4d Mapper Pro on windows 10
