Volume comparison result question.
I have calculated the volume of a pile of dirt on three different dates.
March 24th
April 3rd
And April 10th
I asked for a volume comparison to be calculated. The result in the on overview don’t make sense to me.
The only number I can recognize is the cut volume of April 10th, 510.
I can’t see where the 1221 and 1172 come from. The documentation does not provide an explanation.
What am I missing?
Peter
Hello @petermorssink
It’s difficult to know what might have happened without having the dataset URLs on hand and closely verifying the information.
In this regard, I recommend opening a support ticket and sending us all the dataset URLs you’re comparing in the description. To contact support, please visit this page: Pix4D Technical support services
Kind regards
Thanks, Heydi,
is there a manual you can refer me too which explains what the different columns are in the comparison report?
Please let me know if this information helps you:
  • Cut volume [units³]
    Volume above the base surface, measured between the base surface and the DSM.
  • Fill volume [units³]
    Volume below the base surface, measured between the base surface and the DSM.
  • Net Volume [units³]
    Calculated as: Cut volume + Fill volume.
Kind regards
