Version 1.51.0 Processing fail
Hi, i’ve just updated to v1.51.0 and my project will not process to a a dense point cloud. Using the same work flow as in 1.47 but after adding the GCPs and reoptimizing the processing fails. No indication as to why.
Photos from Mavic 3E,
To add to this i’ve now processed the project in version 1.47 and it’s worked with no issues.
Hi @tim2
That’s weird, could you please share the log files? Help > Export project logs…
Maybe we’ll see something in there. If we don’t, we may ask you for the project, so that we can try to reproduce the issue and fix it.
HI I have reinstalled 1.47.1 as i needed to get some work finished. I will install 1.51 again later and see if it happens again. Itf it does i will send you the logs. etc.
At this moment i can’t open the project (with 1.47) to get to the logs.
Tim
Hi Pierangelo
I’ve had another go at installing 1.51.0 and the project still fails to process to a dense point cloud.
I have then tried to export the project logs and this has failed too…
Any suggestions.
Tim
Hi @tim2 what about version 1.53.0?
I’ve had the exact same experience on two separate projects which calibrated fine, only to fail at dense point cloud creation. Like tim2, I don’t have time to deal with this now that I’ve already wasted time on failed processing attempts. Going back to 1.47 as I have in the past. Very frustrated customer.
Today i’ve downloaded v1.54. this still will not process my data.
I have noticed a warning on the initial calibration but no suggestion as to what or why there is a warning?
Then fails to produce a dense point cloud. (and export the desired laz/las)
Data is from a Mavic 3 enterprise (575 photos)
Processing using the Map template, OSGB36 grid and OSDN datum (OSGM15)
Unlike before I now have a log file that I can share.
2023-12-06_14-37-01.txt (3.1 MB)
Getting frustrated as there are features in this version that look like they could be useful.
Tim
Hi Pierangelo
I’ve now tried downloading v1.54. this still will not process my data.
Workflow is;-
Drag & drop photos
Set Coordinate system (OSGB36 &ODN height)
Calibrate using map template.
Add CSV of ground control points
Link GCP to points in photos
Reoptimize
Dense Point Cloud – density high & export to LAZ.
Works fine in 1.47.
Do wonder if it is a camera issue now that there is more user control over this?
Tim
2023-12-06_14-37-01.txt (3.09 MB)
Hi Tim,
Could you please update your graphic card driver?
It looks like the error is related to it.
Please let me know if it helps.
Dai Shi
