i have a set of images, 147 of them taken with a mavic 2. Im trying to run a process to create just an ortho. No need for gcp’s. It barely even starts to calibrate and fails.
Any ideas why that would be??
Hello @Ryan_Beisaw
Can you share the log files with us? Help>Export project logs
Is this behavior recurring? Have you tried different processing settings?
Hello
I am getting the same error, it is recuring and the job will work if I click start again without changing anything. Log file is over 4mb so can’t upload.
@survey10 Can you attach your log file to this posting? We’ll take a look to see what could be going on.
