Using Micasense Calibration Targets with Pix4DFields?
To this point I’ve only used Pix4DMapper and am giving Pix4DFields a try. When I load the images it detects the calibration target images. However I’ve started processing and at no point has it asked for me to enter the calibration values for my target like you can in Pix4DMapper. Am I missing something or is there not the ability to enter calibration values or is the software so smart it reads the serial number of the target and looks up the calibration values itself?
Good question. Indeed when you are processing with PIX4Dfields it detects the calibration target automatically and reads the values of the target based upon the QR code, there is no need to enter in any other numbers. If it says your target is detected then you should be good.
