When uploading to the cloud, from the Pix4Dmapper, in order to calculate in the cloud, it is not possible to select a folder or project to upload to. This becomes an issue, if I only have editor rights on the folder, instead of having editor rights on the organization. In that case, the upload, including the calculation fails, when starting from Pix4Dmapper.
Can I do this differently, in order to use th convenient upload form mapper or should this be turned into a feature request?
Hi r.thissen,
I am not sure the upload would fail due to those reasons. Do you have a link to the project?
I also want to inform you that there will be significant changes to the processing pipeline early next year. Pix4D is retiring the PIX4Dmapper legacy pipeline from cloud products and implementing the newer processing algorithms based on PIX4Dmatic. The new pipeline offers enhanced features, including faster build times and better integration capabilities. You can read more about this in the article below:
I Do not have a link to the project, as the upload failed.
Any other way that you can check whether this IS indeed the reason of rights?
