Uncalibrated cameras
Hello everybody!
I have some problems with the calibraation of some uncalibrated cameras in this stockpile.
The flight is 110 m (360 ft) and the images of the uncalibrated cameras  correspond to gravel. The image quality is good (293 images). I have tryed selecting different options in the proccesing options panel (I’ve tried using “All Prior” in the camera optimization and Remach), but I haven’t obtain to calibrate the cameras succesfully.
Which options in the Step 1 would you recommend?
Thank you very much for your time
Hi Michel,
I recommend you this article to understand better the cause of this: Quality Report Help
In order to get more calibrated camera, I can recommend you the following:
Menu Process > Processing Options… > 1. Initial Processing > General
  • Reduce the Image Scale (1/2 or 1/4). It often improve calibration.
  • Enable the option “Use Geometrically Verified Matching”. It is adapted for flat homogeneous terrains such as fields where it is difficult to find matches.
  • If you can, flying at a higher altitude with a 90% overlap would make calibration easier.
A last and painful solution would be to manually calibrate the uncalibrated camera.
Hope this will help you,
Hi Marco,
I will try you said
Thank you so much
thanks for your suggestion :parrot:
