Trouble producing ortho/tiff
TB LS 03 09 22 A_report.pdf (2.9 MB)
I typically use Pix4D to process data collected from a Wingtra drone to calculate volumes. Been asked to survey some larger than normal sites and produce an ortho/tiff file. Having a lot of trouble for the first time with the program. I believe my overlap is fine 70/85 and flew at 400’ with terrain following. Being over water is the problem with the uncalibrated photos I believe. Pix4D seems to get “stuck” in the ortho production step in step 3, anyone have any ideas? 3 different flights/sites same result
I would first suggest updating your GPU driver. It appears that you are running an older version and this can cause issues. You can download your latest driver here:
