I’ve downloded Pix4D Survey, I’ve runned the program 2 times and now I can’t launched again. I’ve desinstaled it and I´ve installed agian but it doesn’t work. What’s thr problem? Thanks
Hi @h.rodriguez I don’t know what might be causing that issue. If you look in %appdata%\Pix4D\pix4dsurvey\logs folder, there should be some log files. Could you send those in a direct message to me? Thanks, Nate
How big a project will trial handle?
program asking for open GL dirver 2.0, where do I get?
Hi Michael,
There are no limitations on the trial versions of Survey. In general how big a project it will handle will depend largely on the specs of your computer.
The openGL driver has to do with your GPU. Older GPUs may not support openGL 2.0. When you install Survey I would suggest ensuring that your GPU driver is up to date. You can reference the article below on how to update your driver.
