Tilted 3D model
Hi, we are testing Pix4Dmapper and in one of our models, generated from pictures capture by a phantom 4 pro, the resulting model appears tilted. Is there anyway (without GCPs) to delimitate what is the vertical lines so the walls of the building may appear vertical?
Thank you very much
Hi Isabel,
You can take advantage of the orientation tool: https://support.pix4d.com/hc/en-us/articles/205360385
:slight_smile:
