It would be very helpful if someone recognized this “fog” on Orthomosaic, the task was done with Mavic3T, the field is bare with harvest residues after wheat. First, I get the error that is attached to the screenshot, and then when I go to process the data, I get a blurred field, a blurred result on Orthomosaic.
Thank you very much.
The explanation seems easy, you want to process thermal and jpg images together, that cannot work. You need to separate the RGB and thermal images in separate folders and only process one or the other.
Thank you
