Hi all,
I will inspect a cellular tower. I know the common method is turn around the structure. But there are three cables that support the tower. I was think to go up vertical between supports cables.
Does it have a way in Pix4D capture to be at a distance X from a central point (which would be the tower)?
I made a pictogram so that you understand better.
Thanks in advance
