Similar to previous posts “Easy circle drawing/cut in the boundry file” and “Obstacle marking”, would it be possible to add the ability to create obstacles using a simple shape (circle, square, rectangle, etc) as opposed to having to create the obstacle by drawing the outline with multiple points for each obstacle? Many of my obstacles are trees, and it would be much more efficient if I could simply select a standard obstacle shape, click the obstacle on the ortho and drag the shape to the correct size? The circle option is similar to one of the options to create obstacles when mapping on the DJI controller for my T40.
Even better would be the ability to use the Magic Tool to select not only Wanted and Not Wanted areas, but a third option to also select no fly areas (obstacles). Now that would be truly magic ![]()
