I am processing radiometric LWIR imagery from a Sentera 6x Thermal sensor in PIX4Dmapper 4.10.1 and am having a problem with the thermal Reflectance Map generated by the Index Calculator.
The LWIR Orthomosaic looks spatially correct and clearly represents the orchard rows and individual tree canopies. This is mainly because I change the resolution of the orthomosaic to match the GSD of the themal camera, which is annoying since I have to run processing step 3 twice, one for the multispectral images and one time for the thermal. However, the LWIR Reflectance Map generated from the same images has severe striping/smearing and substantially poorer spatial definition.
I initially suspected this was caused by oversampling because the Boson thermal sensor is only 320 × 256 pixels. I therefore tested different output resolutions.
At approximately 2.5 cm/pixel, the thermal Orthomosaic looks terrible and resembles the distorted Reflectance Map. However, when I generate the Orthomosaic at 17 cm/pixel (considering my flight altitude was 60m), it looks fine.
I then generated the Reflectance Map at the SAME resolution (17 cm/pixel), but the Reflectance Map still has the striped/smeared appearance, looking very much like the ortho generated with the multispectral resolution.
The PIX4D Quality Report confirms that the Reflectance Map was actually generated at the requested 10.2 cm/pixel resolution, so this does not appear to be simply an output-resolution issue.
For this troubleshooting project I am using raw, uncalibrated Sentera 6X NIR + LWIR images. The project calibrates successfully (126/126 images), with a mean reprojection error of approximately 0.17 pixels. The LWIR images also participate in image matching.
I also ran several tests for the initial processing to find the optimal configurations for image matching.
I specifically tested the effect of Keypoints Image Scale and Rematch on the low-resolution LWIR imagery:
With 1/2 image scale, the LWIR camera produced very few useful matches.
Changing to Full image scale increased the LWIR feature extraction. The LWIR images had a median of approximately 361 detected keypoints, but still essentially no matched keypoints (median = 0).
I then kept Full image scale and enabled Rematch.
With Rematch enabled, the LWIR matching improved dramatically: the LWIR images still had a median of approximately 361 detected keypoints, but now had a median of approximately 228 matched keypoints per image, with up to approximately 416 matches in individual LWIR images.
The complete multispectral + LWIR project still calibrated 100% of the images.
The settings for that successful matching test were approximately:
Keypoints Image Scale: Full (1)
Targeted Number of Keypoints: 10,000
Matching Image Pairs: Aerial Grid or Corridor
Geometrically Verified Matching: Yes
Calibration Method: Alternative
Internal Parameters Optimization: None
External Parameters Optimization: All
Rematch: Custom, Yes
Sentera 6X rig processing enabled
Therefore, I have been able to obtain substantial LWIR image matching in PIX4Dmapper. This is why I am now trying to determine whether the poor Reflectance Map appearance is a matching/geometric issue or something specific to the way PIX4Dmapper generates the thermal Reflectance Map.
LWIR Reflectance Map settings:
Correction Type: No Correction
Custom resolution: tested at 10.2 cm/pixel and ~17 cm/pixel
Downsampling: Average
GeoTIFF: enabled
Merge Tiles: enabled
I understand that PIX4D generates an Orthomosaic and Reflectance Map differently. However, the difference I am seeing is very large: the Orthomosaic has the expected spatial structure while the Reflectance Map looks terrible.
My main question is:
How can I generate a quantitative LWIR thermal mosaic from Sentera 6X/Boson imagery that preserves the original radiometric values but has the correct spatial structure seen in the Orthomosaic?
Is there a recommended PIX4Dmapper workflow or specific Index Calculator setting for Sentera 6X radiometric LWIR imagery?
I can provide the Quality Report, example raw images, and side-by-side screenshots of the Orthomosaic and Reflectance Map if helpful.
Thank you.
