Select Input-Image's Geolocations without csv-file
Hello.
I recognize Matic’s workflow like this.
  1. File → New
  2. File → Import images
  3. File → Import geolocations and orientations.
  4. Import GCPs
It is very clear process.
But If I don’t have image’s geolocation file , I cannot select geolocation information.
(Pix4Dmapper can select image geolocation information).
It is a little inconvenient like below.
[input image]
WGS84(epsg 4326) & ellipsoid height (no geoid) Zenmuse P1,
and I don’t have geolocation file (only .jpg files)
[input GCP]
JGD2011 CS09 (epsg 6677) & GSIGEO2011 (epsg 6697) ,
and I have GCP’s file
If I skip [3. File → Import geolocations and orientations.] , z error over 40m or more.
For beginner , It is very complex.
Wold you like to improve UI ?
For example: After imput images, User can select geolocation from pull-down menu.
Best Regards.
Seiichi Takayama
Hi @seiichi_takayama,
Thank you for the suggestions.
As you mention, at the moment it is only possible to change the image coordinate system when importing the image geolocation text file.
When only importing the images, the selection of the image coordinate system is not possible.
We are already considering adding the Image Coordinate System dialog that would address the request you mention. Hopefully it would be added in the second part of the year.
Dear Blaz
Thank you your reply.
I’m happy to hear you already considering my request.
I expect to improve in not far future.
Best regards.
Seiichi Takayama
Hi guys,
We support this request!
We are mapping a lot of forests, and usually don’t need GCP’s and therefore need the image coordinate system to be correct.
If we could get an option like this one from Pix4dMapper that would be great!
Skjermbilde
@Blaz Happy new year! :slight_smile:
Any news on this function?
Hello @Biodrone,
I hope you had a great start of the 2022!
Thank you very much for the feedback and your suggestions.
Your request has been transferred to our development team and this feature will be probably and hopefully implemented within 2022, but I cannot provide an estimation of the date of implementation.
Thanks a lot again for your useful feedback and your interest!
following and wanted to know if there is any updates to this features.
All,
It’s a bit counter-intuitive, but you can change the output coordinate system in Matic by clicking on the pencil next to the “Tie Point” tab at the bottom. This will change the output coordinate system similar to the option in Pix that was referenced by @Biodrone.
