RTK will not connect after battery change
It seems Capture Pro might not be quite ready for prime time! I’ve flown two large mapping projects and was not able to finish either of them with Pix4D Capture Pro. When the drone returns for a battery change, RTK shows disconnected and, when I click connect, I get an error that says RTK cannot connect, try again later. Very frustrating!
I’m using a DJI M3E with RTK module and an Emlid RS2+ base unit connected to NTRIP service for corrections. The base unit maintains a “fix” solution and the Pilot 2 app on the M3E is receiving RTK corrections from the base. I switched to Drone Deploy both times and flew the missions with no problems.
Any thoughts or advice?
Hello nfldrones,
Welcome to our community, and thank you for your first post!
We’re sorry to hear about the issues you’re experiencing with RTK connectivity after a battery change in Pix4D Capture Pro. To better assist you, could you please submit your flight log through our support page at Pix4D Support? This will help us diagnose the problem more effectively.
Thank you, and we look forward to helping you resolve this issue!
Fernando Torres - Technical Support Specialist
Thanks for the response Fernando! I’ll get the logs uploaded today.
Kevin
