When I upgraded to the latest Pix4d Mapper desktop, my menus and font size are huge so much that I can’t see some of the information. Has anyone experienced this or nor how to reset the size of everything?
Hi @michaelgray,
Thank you for your message and for sharing the screenshot.
Please try this procedure:
- Open your device’s settings (Windows)
- Select Display
- (optional) if you are using multiple monitors, select the monitor where this issue is appearing
- Scroll down to Scale and layout and modify the Change the size of text, apps, and other items until you find the best fit for you.
Let us know how it goes.
Cheers.
CAUTION: This email originated from outside of the CONSOL Energy Inc mail tenant. Do not click links or open attachments unless you recognize the sender and know the content is safe.
[https://sea2.discourse-cdn.com/pix4d/user_avatar/community.pix4d.com/daniele_lecci/45/4345_2.png]
Daniele Leccihttps://community.pix4d.com/u/daniele_lecci Daniele_Lecci Technical Support Team Lead
April 25
Hi @michaelgrayhttps://community.pix4d.com/u/michaelgray,
· Open your device’s settings (Windows)
· Select Display
· (optional) if you are using multiple monitors, select the monitor where this issue is appearing
· Scroll down to Scale and layout and modify the Change the size of text, apps, and other items until you find the best fit for you.
Cheers.
Hi @michaelgray,
Unfortunately I can’t read your last message. I can only see my own message.
Please connect to the Pix4D Community and write your message.
Cheers
