Display issue - Cannot center the image with mouse
I’m having trouble viewing Greetings, thank you in advance for any help. I need to edit my cloud of points, but I’m having problems with visualization, note in the photo below that the spatial orientation is a bit out of place, so I click on a location but the action is well off, I can not center the image at the mouse pointer . I have already closed and opened the file n times, I have restarted the computer several times and it is not resolved. Any suggestion? Thank you.
In this image note the pix cursor far from the mouse pointer …
I believe this is the same issue as in this post. For convenience I will copy the answer from the other post:
"This seems to be a display issue. Can you try this out and let me know if it works:
Right-click on the pix4dmapper.exe file,
select the Compatibility tab and
enable ‘Disable display scaling on high DPI settings’: the checkbox below should be checked.
Let us know if that solved the problem. Thanks!
Eu agradeço Pierangelo pelo pronto atendimento, são estas atitudes que fazem o Pix4D o líder do seguimento e o melhor índice de satisfação dos usuários.
Eu não cheguei a usar a sua solução, mas resolvi então vou compartilhar o que fiz.
No momento que estava tendo problemas, eu estava com minha área de trabalho do windows duplicada, utilizando 2 monitores. Então eu desabilitei a duplicação de tela e o problema se resolveu.
Fica aí então mais esta solução.
Mais uma vez obrigado.
Thank you Daniel! For your positive feedback and for sharing the solution you have found. Glad to hear the problem is solved. All the best!
Dear all,
I had the same problem and I solved it disabling my sencond monitor.
Thanks Daniel!!!
Thank you @marzocristian for your input and suggestion!
