Relocated image folder: how to re-associate folder to project?
I inadvertently preocessed the project when it sourced the images from a USB drive. (eMotion  postflight)
I have moved the the img folder to the main / root project in with Initial etc
No images appear in the raycloud or when doing MTP etc.
How do I re-link the folder please?
Thank you
Hey Troy,
When you are moving a project you also have to move the .p4d file, input source images and the output processed folder and it should follow the same folder structure.
Please take a look at the link below for the folder structure setup:
https://support.pix4d.com/hc/en-us/articles/202558649-Project-Folder-Structure
