I spend a considerable amount of time cleaning the 1 GSD orthomosaic. However, I often want lower resolution copies of the cleaned orthomosaic. Changing the resolution in Step 3 loses all the edits made on the 1 GSD ortho.
I have been successful in reducing the resolution in Photoshop, but the .tfw file does not properly place and scale the ortho properly. Is there a way to manually change the .tfw file (or metadata) for the reduced-resolution ortho so that it comes in properly. Below is an example of the info in the .tfw file.
You save the same project with different project name and process the step 3 by changing the resolution of project saved in different name. The original project processed data will not be lost…
Thank you! This method worked perfectly, and was very easy to follow. It is helpful in my work to have different resolutions of the same georeferenced orthomosaic. Thanks again.
Cookie Policy
